Need help with a strange noise in front end!
Disconect the sway bar mounts at chassis, move sway bar rubber bushing aside and lube with white lightning spray grease. Reconnect and most likely the noise will be gone.
I installed a pro comp coil spacer lift and have clunk on the passenger side rear. I know have a squeak/creak in what sounds like the same fender well. Can't find either one, it's driving me crazy
yeah i checked my drag link and it seems that it is more loose than normal. I can grab the bar and jiggle it, and it seems to make the same type of noise as i mentioned before.
Ok so i tightened up the drag link and it still makes that same noise. Next bet ill check the U joints and ball joints i guess. Going to take it in tomorrow and have a shop look at it.
