Need help with rubi build
Ok thanks. I'll wait on drive shafts. Has anyone used the 2.5" rock krawler lift? If so what was actual lift after adding front and rear bumpers?
Ok for update I've got almost everything figured out. Talked to rock krawler and they said actual hight is 3" front and 2" rear and shouldn't sag anymore than 1/4". So the only thing left to figure out is shocks. What do u guys think? I've heard stock rubi shocks were good so should I just buy extension brackets or should I buy new longer shocks. I'm thinking new shocks but not sure what shock to buy. I couldn't find anything by searching shocks on the forum.
There are tons of shock options. Lots of people will recommend either Bilstein or OME shocks. Two totally differnet rides. the Bilstein will give a better on-road ride and will feel more stiff. The OME tends to get better reviews for off-road and you may get more of a softer ride with more body roll. Something about how the shocks react with Bilsteins having a more immediate rebound vs. a slower recoil on the OME's.
Both are great shocks and will give a better ride then stock (I have the Bilsteing 5100's and its way better than my stock shocks) and will pefrom well off-road. There are tons of other brands but these two are talked about quite a bit here.
price wise, they are similar...OME's may be a bit more but expect to pay around $70 to $90 a shock.
