Need help on rock sliders
Old 12-21-2007 | 07:20 PM
  #21
ShrockTaco's Avatar
Former Vendor
Originally Posted by cab76
I think there is a rail that has a flat plate from the frame to the rail on their product, not sure which one it is. I've been wondering if you could weld something on to the shrockworks rails to create a flat surface??
In short sure you can, but with the way the sliders bolt to the frame rail if you weld something solid across all 3 legs (assuming you have a 4dr) then how would you remove the rock rails if you "had" to remove them at one point in time ? A better Idea would be to create panels that would bolt in between each frame leg that could be removed in the event you needed to remove the sliders.
