Need help with mirror reloc. brackets!!!!!
OK, I give up!!! I got a set or RR mirror relocation brackets, with no instructions. Mounting the RR brackets and the hole cover is a no-brainer. BUT, how in the h*ll do you get the mirrors out of the factory brackets!!!!!!!!!
I have tried everything short of taking a hacksaw to the factory bracket. Any suggestions??
just keep wiggling. basically shake the entire vehicle to free them. don't forget to add the grey plastic inserts to you shaft holes on th RR bracket into mid 2008 and later models.
if you need i'll find and post my instructions
Finally got the driver's side loose. You're right I literally had to shake the entire vehicle. I did not get any "gray plastic inserts". Not sure I am even going to do the right side, since fromwhat I've heard the right side is pretty much useless with the reloc. bracket.
I just did this and yes, it takes a lot of wiggling and twisting to get the mirrors out of the factory brackets. I didn't bother putting the right side mirror back on as it cannot be seen with my soft doors on.
I installed and immediately uninstalled the passenger side bracket. Most states require two mirrors. Rear view and drivers is enough. Disclaimer: Check you local laws.
When I did mine I had major trouble getting the mirror off on the driver side. Ended up putting a drill bit in the hole and tapping it with a hammer. Came right out.
Put a phillips head screwdriver in the bottom where the bolt was, and use a small rubber mallet to bang it. Should fling the mirror right off. That is how I got mine out. Also be ready to catch the mirror when it flies off. Due all this with the doors still mounted on the Jeep, much easier.
Pretty easily done with mirror still on door. After you take the bolt completely off from the bottom, hand screw it back in, just 1/2 or 3/4 of a turn or so. Take your mallet or hammer and give a few taps upward on the head of the bolt. Should bust it loose, and the bolt being still there keeps the mirror from flying off. Once loose, remove the bolt and remove the mirror from the bracket.
And x11ty million on leaving the pass. side as is ........... Unless required by law to have on over there when not running doors.
Anthony
Anthony
