Need help with a Lift question, what should i go with?
Old 08-25-2012 | 08:40 AM
  #21
Teetertotter's Avatar
Default 2.5" Teraflex lift on 33's pics as requested
ID:	357916Click image for larger version
ID:	357917Click image for larger version
ID:	357918Click image for larger version
Old 08-25-2012 | 08:41 AM
  #22
J.cyr8's Avatar
Originally Posted by Teetertotter
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=357916"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=357917"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=357918"/><img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=357919"/>
Beauty thanks!
Old 08-25-2012 | 08:44 AM
  #23
Rooty's Avatar
Default 275 79 18
Originally Posted by J.cyr8
Nice! So that's 2.5" OME springs with skyjacker shocks? She rides comfy? Tire size?
They measure 33" on the jeep 35 psi. Check out my profile for other suspension components I used. You don't need it all but you do need some stuff like rear brake line extension brackets and front and rear links are nice.
Old 08-25-2012 | 08:46 AM
  #24
J.cyr8's Avatar
Perfect! You've convinced me to stick with a 2.5" lift instead of getting a 1.5" leveling kit. Looks good! Obviously there's a benefit to getting longer shocks, but how bad is it to get shock adapters instead?
Old 08-25-2012 | 08:59 AM
  #25
jkd3624's Avatar
I had 33's. With a 2.5" lift I don't have pics of them now. But if you have the stock flares on they look nice on it. Even with bush whakers they will look ok.
Old 08-25-2012 | 09:01 AM
  #26
J.cyr8's Avatar
Ya it was either cut the flares, or get a lift kit for clearance. But, as most jeep owners do, I love the look of a lifted rig. I know it's a bit more costly than just trimming my fenders, but you can't go wrong with lifting a jeep
Old 08-25-2012 | 09:15 AM
  #27
Ang3L's Avatar
Originally Posted by Bull
A lot of people not happy with skyjacker. OME and taraflex have a lot of excellent feedback.
I agree!
Old 08-25-2012 | 10:42 AM
  #28
Rooty's Avatar
Default I don't recommend it
Shock extensions are expensive for what you get. I found the red stock shocks with stock springs stiff. M95's were cheap enough from quadratec. Ome or bilstien would be a good choice. I am very happy with what I have. If I was to do it over again I would one stop shop from Stan at northridge4x4.ca
Old 08-25-2012 | 03:23 PM
  #29
beermantsw's Avatar
I have a 2010 rubicon and I just put in a rough country 2 1/2" lift, I got the budget boost it came with springs and shocks for $ 360 and I had to buy break line extenders for $ 10 and rear sway bar extension for $ 40 . I rides nice and looks great too
Old 08-26-2012 | 12:05 PM
  #30
andrw's Avatar
Looks like it squats a bit in the back. Is that normal for the TF 2.5" ?
