Need help on control arm settings
#21
#22
I'm probably 1/2 to 3/4 degree high on the rear pinion and it is smooooth, cruising, speeding up, or slowing down. Much better than the stock shaft which may have been poorly balanced or had a bad flange.
Checking the front caster is a bit tedious, you have to make sure the angle finder is properly positioned. Turning it a little bit left or right causes the readings to be off.
Verify your positioning with the numbers they gave you and go from there.
