Need help building hoist on concrete ceiling.
1 Post
The ceiling to my house in my garage is concrete. How can i make a hoist system for my hardtop. I don’t know how to get parts attached to the ceiling because it is made of concrete. Any ideas or solutions would be much appreciated. Thanks!
I've used tapcons from Home Depot on walls many, many times without issue. They hold extremely well but I have never done it on a ceiling. They're like screws that go into concrete after predrilling. They have all different sizes.
Tapcon 3/16 in. x 1-3/4 in. Philips Climaseal Steel Flat-Head Concrete Anchors (75-Pack)-24355 - The Home Depot
Is there a Fastenal near you ? They have lots of options. You will need a hammer drill though.
I would refrain from using Tapcons ( the blue screws) for any overhead hoisting.
Use a hammer drill and a two part epoxy to glue the fastener in place. Make sure to clean the hole out good with clean compressed air and a hole cleaning brush. Simpson makes plug caps to help keep the epoxy from running out or you may have good luck with duct tape.
U can also glue up some 2x4s with liquid nails/ construction adhesive and use tapcons/ lag bolts with shields to attach to the ceiling then u can run the hoist system off the 2x4's like normal.
