Need help broken lug key
Old 11-08-2008, 05:56 AM
  #21
WRAITHYJEEP's Avatar
grind off chrome and mig weld a nut on it that's what i had to do when my key broke had to do all 4
never ever put lock nuts on it again
Old 11-08-2008, 06:10 AM
  #22
RedneckJeep's Avatar
Originally Posted by Willy J
So I finished putting on my lift today and when I put my wheels back on, my key for my locking lugs broke. Problem is I have my new tires coming in a few days and need these lugs off.
They're McGard lugs that are smooth on the round as the key engages inside the lug. I have the security code to order a new key but that'll take weeks to get and I don't want to wait that long. What am I going to do??? Any suggestions are welcome. I thought of having a buddy weld an old lug on top of each locking lug to facitlitate getting them off.
Thanks!
Find a 1/2" drive socket that will BARELY NOT fit over the lugs. Then, tap it on the locking lug with a hammer. Take a 1/2" ratcher or pull handle and break the lug loose. Works everytime.
On EDIT. I saw where someone else had already mentioned this and you said there wasn't enough room. The mig welded nut on the end is probably about your best alternative then.
Old 11-08-2008, 07:01 AM
  #23
Thanks for all the advice guys. I'm gonna give McGard a call & see if they'll overnight it. If not, I'll have my buddy weld a nut on them & we'll do it that way.
Old 11-08-2008, 09:54 AM
  #24
TexsDream77's Avatar
When I worked in a garage we had a tool for this from snapon. They came in a few sizes. It was basically a socket with a round opening instead of a hex. It had a few teeth inside. Tap that on a little with the BFH then hook up the air gun. Push on the gun as you loosen. They come right off. This is how real thiefs steel your wheels in seconds with locks on.
I've also seen these at Sears and harbor Frieght. If you can't find one... call around to a couple of garages. I'd find it hard to believe that a tire shop doesn't have one. They are the guys that showed me this tool some 16 years ago.
Old 11-08-2008, 11:15 AM
  #25
Thanks but my problem is that I live in the sticks and there are only 2 garages here in Town. I'll give them a call on Monday before calling McGard to see if they have a tool like that on hand. I'm done with these locking lugs after this ordeal!!
Old 11-08-2008, 11:40 AM
  #26
Home - Wheel Lock Keys
This isn't the same as the one we had but it looks like it would work.
Old 11-08-2008, 11:57 AM
  #27
lnufnu's Avatar
I bought this when it happened to me..
craftsman "Lug-out"
www.sears.com/shc/s/p_10153_12605_00947392000P
Worked great....
Old 11-08-2008, 02:46 PM
  #28
I knew I saw a set of those at sears.
Old 11-08-2008, 04:04 PM
  #29
gt4660's Avatar
I saw this post early this morning and was not interested. Low and behold when I go to put my daystar leveling kit on The key strips and screws up the inside of the lock. Being here in korea it is going to be a pain!!!! What a shitty product.
Old 11-08-2008, 10:05 PM
  #30
See ...you weren't interested in my problem and Karma bit you in the a$$. Just kidding, I feel your pain!!
Quick Reply: Need help broken lug key
