Need help broken lug key
So I finished putting on my lift today and when I put my wheels back on, my key for my locking lugs broke. Problem is I have my new tires coming in a few days and need these lugs off.
They're McGard lugs that are smooth on the round as the key engages inside the lug. I have the security code to order a new key but that'll take weeks to get and I don't want to wait that long. What am I going to do??? Any suggestions are welcome. I thought of having a buddy weld an old lug on top of each locking lug to facitlitate getting them off.
Thanks!
Thanks!
Good luck with this. I a similar thing happen several years ago with McGard lugs and I could not find anyone that could help me. I had to wait on the new key. Have you tried to contact
McGard and see if there is anyway to expedite the key?
Here ya go. Grind both sides of the round part to acheive a partially flat surface. Then take a large pair of vice grips and put everything you got into it. It will come undone, I've done it before.
Good luck.
Good luck.
I have never done it, but if you don't mind damaging your locks, try hammering on a slightly smaller socket with a BFH and carefully turning it with a breaker bar. I have also seen a product in the auto stores called an "emergency lug nut socket" that has teeth that might grab onto the lock. Just my thoughts, no experience.
I had the same problem on an older set of locking lugs. I used the socket method, hammering it on, then using a breaker bar to loosen it. This is what I was told at the tire shop when I went to them with my problem. It worked like a champ. Good luck!
Have you tried one of those gator grip sockets? I'm not sure if you can get one big enough for a lug. That being said, vise grips or a big set of channel locks is probably your best bet.
Done this and it works great....you can pick up a socket at Pepboys made for this....works great but is a biatch getting the old one out so you can do the other 3.
I have had to do this before also. The method I used worked but it will ruin the lug nuts. I took a fairly sharp metal chisel/punch and put it at an angle and then hit it with a BFH until it broke loose. It works but the only downside is if you miss or slip it can put some scratches on your wheel. Hope you get them off.
I guess it's safe to say that if I do this my socket is toast? I only ask because I'll have to do four.
