Need help!!! Bearings and axle shaft
the past few weeks i have a heard a chattering noise form the rear of my 09 wrangler, 2.5" lift, 22" rims. took it in a the dealer said both bearings are out and i may need a new axle shaft? what is the reasoning behind this? anything i can do to prevent it form happening again? PLEASE HELP.
If the bearing went bad, you may not have had enough oil in the differential. You may have hit a rock or something while wheeling. It may have just been a bad bearing.
If the axle bearing is bad, and the dealer wants to replace the entire shaft, either they don't want to take the time to remove and replace just the bearing, or the bearing is seized and took the shaft with it.
