need help with axles and big tires
#21
![FJOTM Winner](https://i.ibb.co/FgFLpFN/Untitled-1.jpg)
The only labor I added in my description was for gear install so figure about $600 off the quote I had earlier. But add some more back in for "bulletproof". If you have an automatic add another $5k for a supercharger or $15k-$35 for a ls swap so you can actually turn the wheels.
#22
![beer](https://www.jk-forum.com/forums/images/smilies/beermug.gif)
#23
the Reason For This Build Is Because A Guy At Work Had 40 Inch Tires And I Couldn'tBelieveHow Good It Looked I Talked To Him And He Just Beefed Up His Axles And Ran 5.13..... HE Said There Was Never A Problem In The Axles But I Am Going Bigger Axles Now... Asked How Can You Move Those Tires With The Little Motor....He Said It Wasn't To BaD....Probably gGoing 5.38 Gears thanks For All The help
#24
#25
When it comes to this question I'm a broken record...I did a ton of research and I went with Dynatrac pro rock d44 up front and the pro rock d60 in the rear, synergy ball joints, RCV axles, 5.13 gearing and ARB lockers.
but I am only running 37's...
if your serious about 40's then go with a d60 up front.
matthew
matthew
#28
#29
Forum Tech Advisor
#30
not at all. Im about to go to a rubicon express 5.5 heavy duty 4 link long arm kit. Im only running 37. When u get in those rocks i would rather lift a wheel then rub. But im also going 6inch so when i can afford prorock60s i will not have to change my lift to run the 40
