Need Help/Advice with set up.
Ok, since I installed my new tires 285/70/17 Hankook ATM's load E on stock rims with 1.5 spidertrax spacers I seem to get a shacking/vibration/wobbling coming from the front end starting at around 40-50mph, the steering wheel doesn't really shake it just seems like the front end is shacking/wobbling. When I am doing under 40mph I can feel it at all. Does anyone know what might be causing this? I was going to take it back to the dealer since I only have 2500 miles on it and see what they say.
That said, it's most likely your tires are not balanced properly.
I checked all the lugs on the spacers and rims it's not that, I may have to have the tires re balanced and see if that is what is causing the problem, if it;s not that maybe a tire is bad.
