need help with 14 jk unlimited sport
Old 08-24-2014 | 07:59 PM
MasonAlex's Avatar
Default need help with 14 jk unlimited sport
im thinking about getting bigger and wider tires with after market rims not for sure what rims yet cant decide on right rim, but im a noob when it comes to tires and rim im wondering whats the biggest widest tire would fit a after market 16x8 rim. I want know rubbing when im off roading im a weekend warrior so im more on road then off but i was thinking about a 32x11 tire what would my back spacing neeed to be if any on the rim for no rubbing?
thanks so much!
Old 08-24-2014 | 08:10 PM
nthinuf's Avatar
The two threads stuck right to the top of this modified area would be a good start. Are you planning to cut the stock flares or add flats? Any fender coverage laws to worry about where you are?
6.25" is the stock backspacing. A 4.75"-4.5" backspace is fairly popular, and can run 'most' 35x12.50's with no rubbing, assuming enough lift or flats for wheel well room.
Old 08-24-2014 | 08:35 PM
MasonAlex's Avatar
no theres no laws were im at but i wasnt trying do a lift atm just the bigger and wider tires
Quick Reply: need help with 14 jk unlimited sport
