Need control arm lengths for 3" lift.
Fixing to swap from 4" coils to 3" coils and need advice on control arm lengths. I have the basic knowledge for adjusting and setting the correct pinion angle. I know somebody has a 3" lift with adjustable control arms that could just give me the answer I need. Thank in advance!
What brand suspension? Try their web site for specs first. If not available, here's what worked for me when I was on a short arm: Front upper 18 7/8 Front lower 23 1/4" Rear upper 18 1/8" Rear lower 20 1/2". TAke with a grain of salt, because there are variations depending what loads you're carrying and pinion angles/caster you want to dial in. The lowers set your bump stop alignment, the uppers set your angles. Hope this helps.
