need to choose new gears
Old 03-12-2011, 05:38 PM
OFP4LIFE's Avatar
Default need to choose new gears
ok i have bought a 2010 unlimited sport with 3.73 gears and when i put my 35" dick cepek crushers it was lacking how do i say this "BALLS" so i was looking at getting 4.88 but i dont know what brand and how much so i be spending
Old 03-12-2011, 06:21 PM
Pat Vigeant's Avatar
Default Gears
I just re-geared my 2 door with 5.13's. If you look around you can find some deals for around 1000.00 installed (in SOuthern California)
Pat
Old 03-12-2011, 06:47 PM
OFP4LIFE's Avatar
do you have a manual or auto if auto whats ur rpms at 65?
Old 03-12-2011, 06:51 PM
modestoperandi's Avatar
Check out Off Road Evolution in Fullerton. I'm pretty sure they still have their $1000 gear special.
Old 03-12-2011, 07:01 PM
OFP4LIFE's Avatar
i was thinking more along the lines of ordering gears and having the dealership install them cuz im in th middle of no where Off Road Evolution is 2hrs 30 min away from me other wise i would be on that. palm spring area is as far as im trying to go.
Old 03-12-2011, 07:12 PM
OFP4LIFE's Avatar
Originally Posted by ludski
check out northridge4x4.com
great deals with Dave.
i would say 4.88
unless you do some towing or live in hilly areas, then 5.13. and also a superchip to program engine better.
if you have a manual though, 4.88 would be the way to go.
i got the auto. no towing, not much hills. other then off roading. but i do drive alot so im trying to keep rpms down a little so i have better gas milage. but it would help if i can get the better performance. and i have been looking for a re programer and have been looking at the superchip. but still have a hard time to commit. trying not to spend more money then i need to.
Old 03-13-2011, 11:03 PM
thombull's Avatar
5.13 for 35 in. tires or above with auto, if it was a rubicon (Dana44 front axle) then 5.38's...
Old 03-14-2011, 08:35 AM
Taco's Avatar
I have a 07 X with manual. It came with 4.10 gears vise the stock 3.86. I was running 2800 RPMS at 65. I just lifted my jeep and put 35in BFGOODRICH all terrains. I used the AEV PROCAL module, now I am running 65 at 2300 RPM. Using a little less gas and hills well have to drop to 5th on long hills.
Old 03-14-2011, 09:14 AM
Enclocal's Avatar
5.38s is WAY overkill for 35s.
I disagree
Since, OP does not have a Rubi, this is a non-issue for this thread
Old 03-14-2011, 10:48 PM
Red Dog's Avatar
I have 35’s and went with the 4.88’s because I do a lot of highway miles. The most common is the 4.88’s and the 5.13’s both are better than what you have now. You can use 5.38’s just don’t drive 90+ mph on the freeway.
Quick Reply: need to choose new gears
