Need Answers about Busted Drive Shaft
Alright I just got my jeep a few days ago after being lifted. The pinion angle was set wrong and was getting severe vibrations, the shop that did the work said it would be fine to drive until my gears came in. Well it wasn't it was a Rubicon Express Rear drive shaft. So I was pulling out of a safeway trying to take a left turn and SNAP . . . Thunk . . .Thunk . . . Thunk. Shift into 4wd and make it back off the road and pick up the pieces and it was the U-Joint closest to the T-Case that blew apart and spit the top half of my drive shaft in the middle of the road.
So what do I do. Was it the shops fault for setting the pinion angle wrong? Was it a defect? Or is that my 3.21 gears have too much torque for the 37" meats?
Please let me know b4 I have to talk to the shop tomorrow.
3.21's with 37's... wow. Thats a high ratio. It would require roughly twice the power to move in comparison to stock. That will put a lot more stress on the driveshaft. However, having a bad angle like that where its on the verge of binding is going to make things much worse. So while it was most likely caused because of the two things together, it would not have happened if the pinion angle was properly set.
I am curious as to why they didn't set it? Changing your gears has nothing to do with pinion angle.
They said it was wrong when they gave it to me, but said since they were going to be doing the gears anyway they would just adjust it then. I'd hate to say they got lazy, but I wish they would have just did it when they did the lift.
So I am trying to figure out if they are going to try and shaft me, and say its my fault. Or is it on them? I really don't wanna have to pay for it. Getting pretty broke.
If you just popped a u-joint, I'd say just give me another joint, If you twisted the splines, shitty driveshaft, they need to replace it. Where you poppin the clutch or gettin on it real heavy, with 3.21's your askin to snap a joint if you get on it hard.
I see no reason why it should be on you. You were not off road, and just a handful of miles since you got it back (well, I am assuming its just a handful of miles).
JK-Forum Founder
