View Poll Results: Wich Winch?
WARN VR10000 with Synthetic Line
11
64.71%
Smittybilt X20 10 Comp series with Synthetic Line
6
35.29%
Voters: 17. You may not vote on this poll
Need advice: WARN VR10k vs. Smittybilt X20 10k
Hey guys, I need a little winch advice, and I don't want to start a WARN is king thread, just need first hand advice on these winches.
The WARN has the name, but I'm worried about buying any model considered to be "entry level" like the VR series.
The Smitty X20 has the bonus of being waterproof. I will be getting the synthetic line on either choice.
Synthetic versions: The WARN would be around 829, and the Smitty is 649, a 200 difference in price.
It seems the choice is between the bottom product of the top brand, or the top product of a cheaper brand.
I really don't want to spend more than 700, and it must be synthetic line and preferably waterproof and at least a 10k lbs rating.
I'm also open to suggestions on other winches.
This is my DD and I would only need this occasionally, but I don't want to waste money on something that "may work once or twice".
I had a bad experience with Warn in the past. I currently have the Smittybuilt X20 10k and have had zero problems with it. My thoughts are if you wheel a lot, and hard neither are the best choice. But if you only will use it occasionaly go for the Smitty.
But like with lifts, tires, wheels, and everything else, everyone will have an opinion that is just as valid as the last. Go with what you think will work best for you.
Why don't you check the Engo winches from JeepAddOns a sponsor on here.... talk to Chris. Nothing but great reviews and you'll get a 10 000 with synthetic line for under $700
quadratec
they have new winches out, That being said I have a smittylbuilt which I heard was actually a mile marker but renamed and besides the handle rusting and the solenoid mount being crappy the thing works great , I have always had warns inthe past but he higher end ones, the were great
I was in the same boat and went Smitty X20 10 K...why... well I have seen Warns blowup on the field which left a bad taste in my mouth, and after considering the price points of both and knowing that the Smitty has a great rep, it was a no brainer....... go full submersible instead of bottom of the barrel Warn. This is my just my experience, I know everyone has their own opinion.
I am happy with the smittybuilt. I have the x20 10lbs and have used it several times and pulled very hard, no issues to date. other than the freewheel is hard to get started sometimes.
