Need advice on going BIG.
#41
I see that Nitto does make the Mud Grappler in 38's. And it is wide. I wonder if I did the 4" long arm with flat fenders and 37/38, it would sit like the red jk.
#42
yes, 33s are too small, IMO, with a 2.5" lift. with flat flares and the right bump stops, you can fit 37s on a 2.5" lift, but 3-4" would be better with 37s. personally, if i were you, i would start beefing up the axles and regear while you have the 33s. when the 33s wear out, or your budget is there, move up to either a 4 or 6" lift and 38s or 40s. i dont remember seeing if you have an auto or 6spd, but remember, a 6" lift will require more things to run right than a 4".
#43
obviously not exactly, but damn close. it would look and drive like a dream too, on and off road. i have the TF 4" short arm lift with only front LCAs and it rides great.
#44
#45
I guess I have a lot to study up on but in a nut shell, how does one go about beefing up the axles? Is it bolt on parts or is there welding/cutting involved?
#46
LCA= Lower Control Arm. Its the "bar" you can see attached to axles running from just inside and to the rear of the front wheels back towards the frame, terminating approximately under drivers door and in the rear running from the axles just inside the rear wheels towards the front of the vehicle terminating also up on the frame. Usually has a cool manufacturer name like "Teraflex" or "Rock Krawler" stickered to it!
#47
Nearly 1 1/2 years in the making we decided to start out the right way for our second JK by starting out with a Teraflex 6" Elite LCG setup
#48
I think its a worthy addition to building a serious trail rig that is also a daily driver. Now if you want to talk about "REAL cages", search for the EVO 1 streaming shop thread and look a Offroad EVO's work on their rig called EVO 1 or search for the thread "the official carolina truggies build", those are serious competition cages for a JK.
#49
Suggest you do alot more research before pulling the trigger to buy anything..... lots of us learned the hard way it's best to do it right the first time rather than swapping parts/lifts/tires etc...... We found this out on our Black JK and we paid alot for that lesson......
#50
BKGM, absolutley no squeaking or rattling from the cage. It is definitely not a "full roll cage", but noticably tightens the vehicle up, maybe I am just imagining it, but the jeep feels stiffer, less body flex, kind of feeling. I have owned several "race" cars that were barely street legal, some had full cages, some more along the lines of a bolt sport cage like this, so I had some experience with cages to compare it to.
I think I'll get it. could you poast a side photo of the dash spreader? I'd like to run it around a tray I have up there already.
