need advice..doing minor body work repair
Due to a fight with a barb wire fence,i had some deep gouges /scratches in the front of my hood..
i have filled it up with putty and sanded it out to a smooth finish my questions is after i apply the first coat of paint do i go back and sand it out before the second coat if so what girt sand paper?
also when i finish painting and go to put my clear coat on do i need to sand before i put it on ?what grit (1000 is what im thinkin)
I may be wrong here but here is what I think I did before.
You've already repaired the gouge with putty. I would use some primer on it, then wetsand it with 1000 grit. Paint with touch up paint, then wetsand 2000 grit. Then clear coat it and wetsand 2000 grit again.
After that, use rubbing compound and then polish, then wax.
People have various methods. The best place to look for information is autopia.org which is a car detailer's heaven.
