Need advice on 2" lift
Hi all,
Right now I have the OME nitro charger shocks and I really wanna get the 2" HD coil springs but since I already have the shocks, I'm not sure what else I will need. Do I need to order a front adjustable trackbar, bump stops, etc., as well?
Thanks!
Thanks!
With only a 2 inch lift you will not need anything except springs and shocks, there are 30 different springs for our jeeps from the factory and mopar itself has a 2" lift and it's no different from any other stock keep just different springs, order up them springs and slap them in you will love it
Cheers
Cheers
Originally Posted by blueescapes
Hi all,
Thanks!
Thanks!
Atch, thanks for the personal notes. Was that rear TB absolutely necessary or were you just covering all bases? And what size tire are you running?
Thanks!
Thanks!
The rear TB wasn't absolutely necessary but I could see the rear axel wasn't centered and it bugged me a bit, I ran without it for a few months before I installed it, plus I wanted to make sure everything was correct for a little peace of mind. As far as my tires they are 295/70r17 toyo open country mt's they measure out to be around 32.5 with the weight of the jeep on them.
And what do you think...when I get the coil springs should I just keep the leveling kit installed? I could probably clear 35s at that point but I really don't wanna open up that door if there's even a concern of me not being able to close it. After I installed my lift on my old TJ, I put more money into getting all the bugs out than I care to re-live.
Thanks for any insight!
Have you looked into putting 35s on there and if ya have, what was the verdict? I'm running 275/70r18 now with just a Teraflex Leveling Kit (in case you weren't familiar, the spacer kit gives me about 2" in the front and 1" in the rear) and since I just got a new, much closer job, I'm okay with jacking this baby up. I really want 35s but can def live without them if they cause too many issues.
Thanks buddy! Good advice and sold me...
This is what I'm thinking about doing...
Taking out leveling kit and stock springs
Putting in OME 2" springs
Front adj tb
When getting new tires, err on the safe side and stick with 33s.
Sound like a good plan?
Forgive me but I just had my wisdom teeth yanked and I'm loopy...did you have or know of some pics of a jku with OME 2" lift and 33s? And the ride is great on those springs, yea? My 04 with OME rode like a cloud...
Front adj tb
