Need 2in lift help
Old 03-08-2009, 09:38 PM
  #41
stangjeeper's Avatar
Originally Posted by bigbluejk
thanks guys. I really was not happy about all the extra height at first, but I really like it now. With the castor corected and track arms and firm springs, it rives fantasic. If you drove it you would swear it was stock height if you did not know. the ride is sporty and firm, but nothing close to harsh. I am liking it.
It definitely looks good.
Old 03-08-2009, 09:41 PM
  #42
TAMU Jeeper's Avatar
I just got off Eibachs website and looked at the pro truck lift springs for the jeep, it says itll add 2in in the front and 1in in the rear, anybody have some insight on the springs?
Old 03-08-2009, 09:46 PM
  #43
Id stick with the Tera,RE,RC,OME lines. Dont think you will find many people running the eibachs for lifts.
Eibach makes a great lowering spring though.
Old 03-08-2009, 09:48 PM
  #44
Ya thats probably a better choice, ill keep looking.
Old 03-08-2009, 09:52 PM
  #45
armycop's Avatar
Does anyone know if there is a place that I can get just the coil springs for a 2-2.5in lift, i know Skyjacker sells the springs seperatly but what about OME or Teraflex? All i am looking for is the springs, thanks.
Don't go too cheap when it comes to suspension. Before you put on taller springs, you will need to get longer swaybar links and some longer shocks or shock extensions. It will be a bad day if you overextend a shock or flip the swaybar. You can re-use the rear swaybar link on the front and buy a longer one for the rear.
Old 03-08-2009, 10:09 PM
  #46
bigbluejk's Avatar
way back in the day I had a worked over sho taurus and I used eibachs on it. I have never seen them on a jeep though.
Old 03-08-2009, 10:31 PM
  #47
armycop's Avatar
Default 2" Rusty's springs and .75" front spacer
Mine on 2" Rusty's springs and .75" spacer plus 315/70R17 tires:
Old 03-08-2009, 10:46 PM
  #48
bigbluejk's Avatar
nice rig copper
Old 03-09-2009, 12:09 PM
  #49
Ok guys i just want to clear everything up real quik, so if i run 2.5 inch springs front and rear with a 3/4 inch spacer in the front, will i NEED new sway bar links or track bars? Or can i get by with just springs and shocks? Ive read a lot of different threads on this stuff and i just want to clear it up.
Just a reminder i have a 4door unlimited x completly stock, and its just gonna be a street driver for now with minimal if any offroading.
Old 03-09-2009, 01:16 PM
  #50
bigbluejk's Avatar
I think you will be ok for a while with the springs and just a track arm bracket in the rear. then upgrade as money allows.
Quick Reply: Need 2in lift help
