my suspension build on my 2 dr rubicon
Old 08-13-2011, 08:45 AM
jkrubicon09's Avatar
Originally Posted by nthinuf
Extended bumpstops?
And the cams shouldn't be a huge deal. Find a shop to pull them and weld some washers over the holes. Some people have even just welded the cams in place ad added the adjustables.
yes i will be doing bumpstops. i also talked to daved at northridge and i think im just going to do the rk replacement weld on control arm brackets when i order my teraflex control arms. also, do you guys think i can get away with only doing the front and rear lower control arms with my set up or will it make that much differance if i do the uppers also. also im going to be doing 90% of my driving on road and maybee a few times a year thake the jeeep on some trails or mud here in FLA.
Old 08-13-2011, 09:22 AM
nthinuf's Avatar
Front lower and rear upper, if you only do two sets. The other two sets will be for fine tuning and moving the entire axle forward/backward in the wheel well. (moving the axle is fairly popular on 2doors with taller lifts).
Old 08-13-2011, 09:25 AM
thanks for the info. i guess ill just get all 8 and do it right the first time. David at northridge recomended the JKS or teraflex but the JKS are a lil out of my price range
Quick Reply: my suspension build on my 2 dr rubicon
