My rubi has 3.73 gears? What!
#31
Thanks! I'll do that and let you guys know what they say
#32
A buddy of mine just bought a 2014 2-dr auto Rubicon and I mentioned this thread to him. He went on https://www.moparownerconnect.com/Pages/global.aspx and was able to check out his build details online. Turns out he also has 3.73s, much to his dismay.
Learn something new everyday...
#33
#34
Ordered a 14 Rubicon. When you spec the auto trans the build system requires that you get the 4.10 diffs.
Worked for me. I would not be happy with a Rubicon with less than 4.10's.
We had an 08 with the 3.73's and they were ok but at the limit of effectivness with 33 inch tires. I always thought the 4.10's would be the same level of marginal but ok with 35 inch tires.
#35
damn, you guys had me worried. Here i had an 07 jku rubicon and thought oh shit...
But i looked a bit, and i guess 07 was a 4.10 only for the rubi, and you could get any other model with it if you upgraded.
#36
You can get it at the link I posted above.
#39
You guys can go to https://www.moparownerconnect.com ... register and should be able to see the build of your jeep.
#40
Guys,
Don't forget the gear ratios in the transmissions.
If you look at the final drive ratio on them, the 5 speed auto with 3.73s is geared lower than the 6 speed manual with 4.10s.
5 gear in the auto is barely an overdrive. Plus the first 3 gears in the auto are very low.
