My rubi has 3.73 gears? What!
#21
Weird - nothing mentioned about that on the Jeep website and when you go to build one out the only gearing option for the Rubicon X is 4.10 gears. As a matter of fact, when you view the detailed comparisons between the models, the only gearing available for the Rubi is 4.10.
#23
We actually bought ours off of a lot before they could be ordered. By about a month or so. Basically Jeep built them and sent them to select dealerships. The way I understand it they just showed up on the trucks. I am absolutely positive ours has 3.73 gears however.
<We should've bout the white one that was setting right next to ours with the 4.10s>
#24
#25
#26
That sucks you got the shaft! I got lucky when I found out my X has 4.10's.
I personally think you'll be ok with 35's and 3.73. I'm running 37's on the 4.10. I know quite a few people with 35's and 3.73's. If it's intolerable for you then just upgrade gears then.
Sent from my Galaxy Note 3 while crawling over mini trucks.
#28
I almost bought a '13 JKUR with the 3.73's without knowing it, but luckily that Jeep sold before the dealer could get it delivered so I ended up with a '13 JKUR with the 4.10's and put 35's on couple months later and IMO 4.10's are perfect for 35's.
#29
Yeah! I'm gonna get a vin check and see what it says. Super weird. I purposely found one with 3.21 gears because I planned on putting in 4.88's right away and didn't see a point in wasting the money.
#30
Just email Jeep and ask for your build sheet. Go to their website and contact them via email. Put your vin number in and you'll probably have it the next day.
