My rear springs look Jacked-Up, this cant be right
I have a 2010 2dr, i put on a 3.25 lift ( got 4 out of it) and this is what my REAR springs look like. This cant be correct. I just installed Adjustable LCAs and they are set to stock length. Do i need to make them longer or shorter?
don't see a pic but, assuming they are bowed, that is totally normal for a 2-door with that much lift. it's not a real problem but, in order to fix it, you will need to install adjustable spring perches like the kind jks makes.
Originally Posted by BlueBennett
What about coil spring wedges? I found some at quadratec for $25
I have the jks ones on mine and my springs are nice and straight.
Try the wedges and go from there.
