Is my JK a ticking time bomb???
okay I got an 09' 4 door X, pro comp 4" lift with Rustys 2" spacers in the rear and 1.5" up front. Thats it as far as suspension mods go, I havent put control arms on or adjustable this or that or any of that extra stuff that I read about on here all the time. The thing is my jeep drives fine and I dont really see the need to start buying all that other stuff that are supposed to fix problems that I dont have. I am just worried that one day I am gonna be doing 80 on the interstate and somethings gonna go wrong and get me into real trouble. So if anybody has got any friendly advice it would be much appreciated!! oh yeah I dont wheel very often and when I do its usually just trails with a few mudholes, no rocks or bad rutts or anything.
If by ticking time bomb you mean t-case explosion, speed has always been the last ingredient in the recipe for disaster.
why would that screw up the transfer case? Is it just not made to turn big tires fast or does the gearing need to be changed or something?
Vibration at high speeds will cause it to explode.
The recipe for disaster has been:
lifted
regeared
after market drive shaft on the front (double cardan at the t-case)
bad pinion angle on front axle
high speed
Kaboom!
It takes just the right combination, though.
I thought your mention of ticking time bomb meant you were keeping up on the exploding t-case threads.
lifted
regeared
high speed
Kaboom!
lifted
regeared
high speed
Kaboom!
I guess because it's the 4 door you're definitely better off, but bumpsteer and driveshaft vibrations @ 70mph+ is a scary thought without the right suspension geometry. @ the very least I would invest in adjustable control arms.
Both driveshafts will eventually fail due to the steep angles. Hopefully, you will hear grinding prior to their failure so you aren't stuck in the middle of nowhere.
Your brakelines and ABS lines may fail or get ripped apart if your shocks are long enough for a 5.5"-6" lift. If your shocks aren't long enough for a 6" lift, they will fail prematurely.
It is suprising that your ESP isn't going off with your front axle shifted so far to one side because you don't have an adjustable front trackbar.
Your steering should be much more flighty than stock with a 5.5" lift on stock front control arms. It might be dangerous to let someone else drive your rig with flighty steering.
You should be experiencing bumpsteer-type feedback without steering correction. This could be dangerous if you hit a pothole at 80 mph if you overcorrect and roll it.
If your driveshafts, brakelines, or ABS lines fail while you are going 80 mph--that would be the ticking timebomb that could seriously injure you or others.
If your shocks fail, it will just ride like crap--unless the shock bar pins break while you are wheeling in a compromising situation.
