My E-disco just went Kaput,,, what now,
Hi to all,
I went ryding this week end, and my 2010, rubicon, E-disco just died,
The jeep has 80 000 milles on it, modified with 4 in terraflex, and 35 in tyres. Once this summer I filled the connector with dielectric grease. We have dirty winters here in Montreal with lots of salts on roads. The jeep was always treated with rust gard every year.
It was cold on the trail, I hit water and ice over the e-disco.
Problem: now the light flickers on and off, continiously, on 4 or 2 wheel drive. What does it mean ? I believe the electronic cannot confirm the position. May it be affected by water, I beleive so, since the flickering of light started after the water crossing.
I do not know how to do a diagnostic, I don't even know if the swaybar is locked since I have very heavy terraflex springs and the jeep still runs good on the highway.
would this help:
verifiy the fuse (which one ?)
Remove the plug on e-disco and clean and grease, try the system.
Remove motor drive and clean and grease with light oil spay.
and should I just go to for the EVO mechanical assembly at 100 $, and forget the electronic gadgetry of the e disco. I got a good 3 years out of it anyway (this may be my prefered solution before my next sortie).
Meanwhile, should I continue to drive the jeep to work,
thanks for all comments and help.
ray
would this help:
ray
You can try to clean and dry the conections then apply a light dielectric grease similar to what was there originally. Disconnect the battery for a few minutes while doing this as it should reset the computer. If this does not work then the dealership or the EVO route.
Mine did the same thing, I took it apart so that I could manually reconnect it and get the light out. Now I just use the disconnects I had from a previous Jeep so that I don't have to mess with it any more. If you go the Evo route or opt for a standard sway bar you will need the AEV Procal to turn off the E disco feature so that the light doesn't constantly flash.
Taking it apart is super easy
i have the electric portion of the rubi disco...used the evo disco on it. it still works as sfar as i know. if its your electrics piece and not the whole thing that'll fix it. $10 to pay for my gas to go to the ups store and whatever it costs me to ship it to you and iits yours. might just do the trick. i could probably ship with usps flat rate box for under $10 too. guess it depends on the price for the box it fits in.
So I got it working,
I unplug the battery, clean the connection, and lossen some of the bolts of the apparatus.
My observations,
This thing is not very thight, even locked there is some free play between both parts of the sway bar,
There was at least 100 ml of water inside the mechanical part of the unit, boy what would that do in winter time in Montreal.
My plan is to buy the EVO thing, and install it before end fo month. Thaks for the recommendatinons.
However I'm considering a new Terraflex dual rate bar,, has any of you tried this bar that is 10 % stiffer and has a minimum tork for the trail,
ray
My observations,
ray
I had same issue. I unplugged at motor. I think I was doing 25mph with sway bar disconnected.
It did not like that. Down hill driving.
So I got it working, I unplug the battery, clean the connection, and lossen some of the bolts of the apparatus. My observations, This thing is not very thight, even locked there is some free play between both parts of the sway bar, There was at least 100 ml of water inside the mechanical part of the unit, boy what would that do in winter time in Montreal. My plan is to buy the EVO thing, and install it before end fo month. Thaks for the recommendatinons. However I'm considering a new Terraflex dual rate bar,, has any of you tried this bar that is 10 % stiffer and has a minimum tork for the trail, ray
