My DS
My DS
I have a RK 2.5 flex system on my jeep for over a year now. I do pretty much no crawling, just mudding and trail riding at the camp. Went mudding today and looked under my jeep "I haven't done that in a while" and idk something looks off, or is it just me... How does this look to you guys? Boot still in good condition.
Only reason I looked under it was because I put it in 4wd today, I haven't put it in 4wd in about 6 months. Is that why it sprayed that little grease?
That looks normal. I went to a double cardon rear driveshaft. Yours looks like mine did before I changed. Mine is a 2 door automatic.. Yours looks like one also from the angle. I also had a very mild vibration. Almost unnoticeable. But I did have to go to adjustable upper rear control arms to get the correct angle. It seems the cv type driveshaft can take the angle. I just wanted to correct the mild vibration.
Sent from my iPad using JK-Forum
That looks normal. I went to a double cardon rear driveshaft. Yours looks like mine did before I changed. Mine is a 2 door automatic.. Yours looks like one also from the angle. I also had a very mild vibration. Almost unnoticeable. But I did have to go to adjustable upper rear control arms to get the correct angle. It seems the cv type driveshaft can take the angle. I just wanted to correct the mild vibration. Sent from my iPad using JK-Forum
I would not think it would be a big deal right now. But keep an eye on it. It had to come from that boot. When it gets worse you will see lots of grease. Then its decision time. Either a used stock shaft some one has removed. Or a double cardon. Sent from my iPad using JK-Forum
Also lots of good info on angles and such
Tom woods website is www.4xshaft.com Sent from my iPad using JK-Forum Also lots of good info on angles and such
