Is my CLUTCH WORN or something else?
Hi and thx in advance.
2008 JKU, 3.73's, 35's, Manual transmission, 80K miles.
I occasionally drive up some very steep hills in NC and whenever I do lately the Jeep stalls and it sounds like marbles pinging around in the front end. I had to get into 4 Lo today to complete a failed hill climb due to this and gently let off the clutch until I moved forward without stalling. 1st gear would just not hold and it sounded like marbles in a can until it stalled over and over. I expect something to be worn after 13+ years so no biggie. Ps> handbrake needs replacing as well. Thinking about a new upgraded HD clutch and 4.88's. Thoughts?
Let's find out if you've left anything our of the equation.. Although you say 3.73, 35'' and Manual trans, you've yet to say what lift (if any) has bene installed. Also, where have you been taking your vehicle in for service? Have they been checking the translation fluid or have you even had the fluid changed at any point. I'm under the impression that if you have a lift, it has not been thought out correctly and could be placing components in a bind.
If the clutch disc was worn then you wouldn’t go anywhere, the clutch disc wouldn’t grab the flywheel and pressure plate well. If the pressure plate is worn then pressing the clutch pedal won’t disengage the engine from the transmission. This doesn’t really sound clutch related to me.
I don’t think it’s a binding issue in your suspension or drive train. If this was the case you would likely have issues all the time and not just on an incline.
out of curiosity, when you press the clutch and start the Jeep, does it feel like the Jeep wants to move like an automatic transmission would? This would be a good indication of a pressure plate wearing out. If you let off the clutch and it doesn’t want to move much then you may have a worn clutch disc. But this will likely be noticeable in all scenarios, not just a hill.
Kudos to Ronjenx for creating this chart ...
Even experienced people make the mistake of tackling a too steep hill in 4WD-high without properly setting the ESP. Or, better yet, doing it in 4WD-low (where the full on mode is automatically selected) and the added torque reduces the chance of stalling. Me, just a few weeks ago, LOL (18:40 if not forwarded automatically) ...
user 729872082 (01-08-2021)
I think 4.88 is too low, you'd be pretty well capped at 70-75 mph. I went 4.56 with 35's, 3.8l, and the six speed and almost wish there was another ratio between it and 4.10 that would work a little better on the highway. Off-road it's good though, I enjoy it. I spent over 200k miles with the 3.73's so it's nice to have a little oomph back with having to dump the clutch.
