My build thread
The parts supplier for my dealership said my shafts would be maxed out in height but i would be alright. Its the only worry i have. Most of my buddies drive lifted trucks and they said i could always have a machinist make a spacer for the axle yoke if it was too maxed out.
On the lift I would just get the teraflex 4" and install it yourself. It's not that hard with simple hand tools and just get an alignment at a good shop.
Also, replace all the control arm bolts with northridge's grade 8 hardware kit. Have fun with the build.
I have a 2012 2 door auto with the 3.5 lift and 37s. Due to the cost of the regear I decided to get the chip. With the chip you notice a large difference In your RPM. I can still feel the gears changing late but that's because I'm auto. If you want to run the stock gears in manual you should be fine. But i strongly recommend the chip!!
I have a 2012 2 door auto with the 3.5 lift and 37s. Due to the cost of the regear I decided to get the chip. With the chip you notice a large difference In your RPM. I can still feel the gears changing late but that's because I'm auto. If you want to run the stock gears in manual you should be fine. But i strongly recommend the chip!! <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=501219"/>
Superchip Flash Cal. Very easy to use. And very cost efficient compared to a re-gear
http://m.4wd.com/newui/search.aspx?sku=SCI3570
