My Build Idea.. What am I missing... any suggestions
AEV 2.5" American Expedition Vehicles - Brute Kit, V8 HEMI, Aftermarket Jeep Conversions, Products, Wheels, Accessories and Highline Kits for Jeeps (TJ, JK, WK, XK).
35" Tires on Stock Wheels with 1.5" Spacers for now. Not sure what tires yet.. prolly Toyo Open Country ATII
4.10 Gears (brand? where to buy?)
High Steer Kit Not sure which one. Fox AEV
AEV ProCal for gear and tire size correction.
I use this about 90% on road, some distance hence the gearing and more AT style tires.
NO future desire to move to 37's. The off-roading I do a mix between mud, rockclimbing(Moderate at best) and trail. I am going for much more of an expedition build. This is also my work vehicle and use it to access remote oil field sites so there's that.
I have done a lot of reading and feel I have a pretty good grip on what I am doing. My last jeep was a TJ and was much more of a rec vehicle so I didn't need to depend on it daily like I do my JK.
However I love the collective knowledge we have here and embrace peoples experiences and lessons learned.
2015 JKUR. Pretty Stock.
As long as your suspension is set up right a stock stabilizer is fine. I have 37's with stock, no issues. As far as gears, like he said pretty much made the same, I'd recommend G2 just for the price and 10yr warranty.
G2 sounds good.
Any bad news on AEV lifts. From everything I have read they seem to be well built and complete.
So, you had the option for 4.10 gears when you bought it, but decided to pay 4x the cost and wait until you got it home?
The 4.10 is a small difference over the 3.73 I presume you have now. Not worth the investment. Also, the 4.10 gears are a lot more expensive as you have to buy the OEM gears. Given that you have a JKU and are going to 35s, 4.56 would be the right gear choice. Or, keep the 3.73 and see how it goes.
So, you had the option for 4.10 gears when you bought it, but decided to pay 4x the cost and wait until you got it home? The 4.10 is a small difference over the 3.73 I presume you have now. Not worth the investment. Also, the 4.10 gears are a lot more expensive as you have to buy the OEM gears. Given that you have a JKU and are going to 35s, 4.56 would be the right gear choice. Or, keep the 3.73 and see how it goes.
I have a 2015 and going 37's with 4.88 only because I had these tires from my 2011 jeep and maybe plan on 40s after these wear out.
However, I am constantly learning. I didn't know I had to purchase OEM Gears to go in Stock Dana 44's.
Bought off the lot. Didn't really have the option to choose, I didn't order the jeep. It was a snap decision to purchase the jeep by my company. High side is that the company leases my jeep from me. So as long as I work here I drive free Rubicon. I don't mind paying for 4.56's or OEM gearing if it going to reduce load on my drive-train and keeping fuel economy the same. I realize that 3.73 to 4.10 at 70mph is only about 200ish RPM, however I spend a lot of time bouncing around town going from job site to job site so I am more concerned with 0-30 mph revs then at 70mph I guess. That is why I went 4.10 based on the chart I found it seemed to be the best solution between the two.
You won't notice a difference around town between 3.73 and 4.10. A little on the highway in terms of gear shifts.
Bought off the lot. Didn't really have the option to choose, I didn't order the jeep. It was a snap decision to purchase the jeep by my company. High side is that the company leases my jeep from me. So as long as I work here I drive free Rubicon. I don't mind paying for 4.56's or OEM gearing if it going to reduce load on my drive-train and keeping fuel economy the same. I realize that 3.73 to 4.10 at 70mph is only about 200ish RPM, however I spend a lot of time bouncing around town going from job site to job site so I am more concerned with 0-30 mph revs then at 70mph I guess. That is why I went 4.10 based on the chart I found it seemed to be the best solution between the two. However, I am constantly learning. I didn't know I had to purchase OEM Gears to go in Stock Dana 44's.
