my belt keeps popping off.... need help
my belt keeps popping off... it came completely off of one pull this weekend and i had to replace it and the new one still is popping of like half way... it is doing this on and off road and i can not figure out why. my jeep has 11000 miles on it and should not be doing this... if any one could help me it would be appreciated greatly...
Not covered under warranty?
Are you or someone else installing it? No belt dressing (not recommended)? Proper routing and pulley alignment? Tensioner giving enough tension? Any certain conditions? Cold? Rain? Etc?
You may want to take the belt off and check the belt tensioner and the idler pulley. Could be that one or both of those have gone bad and they're wobbling around. But it's still odd that your belt would slip off if routed correctly.
Most like tensioner, but if not here is a weird one. Never seen it on a Jeep, but I had a car with a bad compressor pump cluch, it couldn't spin at high rmp and would throw the belt. At low rmo nothing seemed wrong -wwiifirearms
Stop going to Micky D's and trying to wear belts that are too small.
