Multiple Codes - HELP
Old Today | 10:32 AM
damonpla's Avatar
Default Multiple Codes - HELP
Greetings. First time posting here. My daughter's 2012 Jeep Wrangler Sahara Unlimited was not starting. Just changed the starter, it cranks (slowly) but multiple codes have been discovered. (so it wasn't the starter) I wonder if anyone can perhaps point me where to start in this chain of events.
P0340 Cam Shaft Position Sensor A
P0365 Cam Shaft Position Sensor B
P06DA Oil Pump Solenoid (?) PCM?
P0018 Crankshaft Position Sensor A
P0019 the crankshaft and the bank 2 exhaust camshaft are out of sync (?)
Certainly, all these sensors have not failed. I would be grateful to any ideas as to where to start on this chain of codes, perhaps fixing them all. She starts her new job on Thursday. Perfect timing !
Many thanks.
Old Today | 11:26 AM
resharp001's Avatar
The one i would focus on there is the oil pump. The variable timing and cams on this 3.6L are completely dependent on oil pressure. If the oil pump or solenoid is not working properly it would then create the issues with the cams and the cam sensors as a result. I would google around testing that oil pump solenoid (should be several vids on youtube) and focus on that one first.
damonpla (Today)
Old Today | 11:44 AM
damonpla's Avatar
I appreciate your suggestion. I will start there and see what I come up with. Many thanks!
