MTR's Rubbing Factory Fenders
My Setup:
Lift = Teraflex 2.5" Coil and Shock lift
Wheels/Tires = ProComp 7069 w/ 4.75" backspacing on 35"x12.5x17 MTR's with 1.5" spacer/adapter
Background:
According to TF and other vendors, 2.5" lift should fit 35" tires. However, when disconnected and full flex, my tires rub the front fenders. After Further research, TF states that it will fit 35's only up to 4.5 backspacing or less. I'm obviously over that with my spacers/adapters. I really like the stance, and want to resolve the issue without removing the spacers/adpaters and without modifying the factor fenders.
Question(s):
1) By removing the 1.5 wheel spacers/adapters, should I completely clear the fendors? Will the additional 0.25 backspacing still cause rubbing?
2) I'm also thinking about adding additional lift. I've thought about either installing 3" teraflex coils (0.5" increase) OR 0.75 Daystar coil spacers (0.75") increase. I know there is significant cost difference ($400 vs. $40); but is there a performance difference between coils and coil spacers? Will either of these lifts clear the 35's from rubbing?
I'm leaning towards the coil spacers, so I can spend money elsewhere; I was thinking about getting a front adjustable trackbar and maybe front LCA's in an attempt to resolve a 'drift to the right' steering problem.
Anything other solutions (unrelated to fender modifications) out there?
Background:
Question(s):
I'm increasing clearance via flat fenders (red arrow) or adding lift (yellow arrow); both results are the same. Is my logic not sound? Or are you saying a 0.5-0.75 additional lift isn't enough?
You need more bump stop. Adding more lift just raises the suspension and when you stuff the wheel it will still hit the fenders. More bump stop at your current lift height will keep the tires out of the fenders.
When running flat fenders you gain the clearance at the body (body lift will do the same thing) but you will still bottom out the factory bump stops before making contact.
You can get rid of the adapters but you will likely rub with a 35x12" tire and 4.75" bs wheel. You might try it an see, I don't know what you are doing with your rig. You typically need 2" more bump stops with 35" tires and factory fenders.
You mentioned bodylift. If I were to go down that road, will 1.25 inch of body lift give me enough clearance?
Not disagreeing, just trying to understand. Why won't lift add more clearance? Flat flares will give me more clearance between the top of the tire and the bottom of fender. Won't the lift do the same, using the factory fender? I'm increasing clearance via flat fenders (red arrow) or adding lift (yellow arrow); both results are the same. Is my logic not sound? Or are you saying a 0.5-0.75 additional lift isn't enough?
I dont' really want to cut my fenders, install a body lift, remove my spacers/adapters, or install new flat fenders.
But I might just go to my original plan get some Bushwackers
