mt logan options for dana 30
thanks!
look's like I might take a few days off with a rental car in the future. one quick Question is it required that the tubes be welded via the inner portion whicj would require carrier removal. as My one "fear" is dicking up the gears setup by removing the carrier assy.
If you can take something apart and put it together again successfully, you will not "dick up" your gears. IF the sleeves require welding on the inner side, all that needs to be removed is the axles and carrier assembly. Just take note of any carrier bearing shims and put them back exactly where they came from. The pinion gear will not have to be removed. As long as you replace the carrier exactly as it came out, no "dicking up" will occur. Remember to re torque the carrier bolts.
