Mpg
Originally Posted by TheTerminator
So what do you think going to happen if you regear? You gonna run higher rpm in 6th. Please tell me why are you in 6th gear with your stock gears?
Mine is an auto. I run it with overdrive off. If you regear you gonna run at X amount of rpm at certain speed. That's all that is going to happen. If you use a lower gear, you can get about the same rpm. It's not going to run any differently if you do that.
