Which mount on Tera Flex tire hinge for Rotopax?
Been wanting to mount the Rotopax gas cans on my TF spare tire hinge but I am not certain which bracket to get. Depending upon what I read there is a $79.00 bracket or a $29.00 bracket, both from TF which say they are for mounting a Rotopax can to the TF hinge.
It looks like the more expensive bracket, the larger of the two, is designed for the hi lift and the Rotopax mount while the less expensive and smaller piece is for Rotopax cans only.
https://lh6.googleusercontent.com/-D.../4838200fb.jpg
I will not be mounting a hi lift on my jeep. All I want is the Rotopax mount. Do these work together or seperate, as a modular system, depending on what the user needs?
Thanks!
Thanks!
![FJOTM Winner](https://i.ibb.co/FgFLpFN/Untitled-1.jpg)
You want just the accessory mount. And then you will need a mount from rotopax.
If I understand it right, the accessory mount will hold either the jack -or- the rotopax. For those who want to use both, you put the jack on the accessory mount, then attach the hi-lift rotopax mount to the jack.
News - TeraFlex Product Highlight: JK HD Hinged Carrier Accessory Mount | TeraFlex Suspensions
