Most important skid plates??
If you were going to get skid plates, which would be most important? what is most prone to damage. Oil pan And Gas tank....And what is the best make
The stock gas tank skid is about 1/7th of an inch thick...one of the thicker stock skids out there (MORE than 1/8" thick...).
3/16" would be a good aftermarket thickness though...closer to ~ 1/5" thick.
The other skids are a lot thinner...more like the typical stock tin foil we see everywhere.
That means your oil pan is a high vulnerability area (The evap can was already mentioned as well) as mentioned above.
The Skid-Row and Rockhard plates look pretty good...If Shrock does for the JK what he did for some other rigs...I might just wait a bit longer for the Shrock versions to come out though.
I agree.
The oil/trans skid plate is, I think, critical. My oil pan has dents in it and I crushed the exhaust cross over and had to have the section replaced. then I installed a belly skid plate and now it is beat up but is pretty beefy and is holding up very well.
Next will be the evap canister.
I also recomend protecting the diff covers. Smash one on a rock and your stopped.
My fuel tank stock skid plate is pretty beat up, but has held so far. I know it is a matter of time before I replace it as well.
