Mopar Rubicon Rock Rail on Unlimited X Question
Hey Everyone,
Quick question for you, I am looking at buying a used set of Rubicon Unlimited Rock Rails. I was looking at these mounting directions and found that it said that you need what looks like a little tab to mount the rails. Can anyone tell me if I actually need this part if so, how much is it? The reason I ask is that it doesnt come with the mounting hardware and the rest of the stuff I can get from the hardware store.
The part I am talking about is labeled "D" in the diagram. Thanks!
http://www.quadratec.com/Assets/Installation/75747.pdf
I did the same thing, installed some rubi rock rails on my JKU X. I was able to get the clip things at my local autozone. I think the size was M5 or M8 or something (they are metric). I had to buy the matching bolts at the same time. When you go to put the clips into the holes, I found that the rectangular looking hole was there, but the round hole for the actual bolt was covered up with a thin rubber sheet (had to poke a hole through it).
