Mopar Off Road bumper and the PowerPlant
Old 11-26-2009 | 10:20 AM
Stuartsbasement's Avatar
Default Mopar Off Road bumper and the PowerPlant
Bought my pride and joy in March with a lot of dealer installed Mopar accessories. One of them was their offroad bumper with the cut out for a winch to sit inside the bumper. Afterwards I was made aware of the Warn PowerPlant. Unfortunately the two do not seem to be an easy fit. I have not seen the PowerPlant in person so I do not know how it would interfere with the bumper hoop. The nice thought is that since the winch sits within the bumper I would have the space to fit it in. Too wishfull I know.
So, has anyone ever tried to combine the two? Either by removing the hoop completely or (the prefered) raised the hoop or removed material from the back and bottom to make the Warn PowerPlant fit?
Ideas comments and especially solution appreciated.
Old 11-26-2009 | 03:12 PM
Steve Young's Avatar
I haven't tried the Powerplant so can't answer your question exactly. However, I do have the off-road bumper with a Warn Ti. The Ti is a pretty tight fit in there front to back.
It would be worth checking that the Powerplant fits the footprint even if you remove the hoop as unless it is the same footprint or less than the Ti then it won't.
If you're set on the Powerplant then it would probably be an easier option to sell the Mopar bumper and get ne that works with the bigger winch.
If it were me I'd go with a smaller winch (e.g. the Ti) and have a separate compressor (e.g. The ARB under the hood set-up). That's eactly what I did do in fact ...
Steve
Old 11-26-2009 | 03:38 PM
geebee's Avatar
Steve
x2 i have the Ti also which measures 6.3 inches deep. the powerplants are 6.7 and 7.0 respectively. i dont think either will fit. i cant even slip a piece of paper between my winch and the front of the bumper and much of the same behind the winch (between winch and grill).
Old 11-26-2009 | 03:40 PM
adamisadam's Avatar
what winches fit in the mopar bumper? smitty builts?
Old 11-26-2009 | 03:49 PM
geebee's Avatar
any winch with the standard bolt pattern. just nothing wider than 6.5 inches or taller than the hoop.
