MOPAR Fuel Door
MOPAR Fuel Door
Anyone have a problem with this item??? I read the write-up and had no problem with installation however after I had put the tailight back on I realized that the entire "housing" seemed to shift about an 1/8 in back and forth. I made sure the seal was on correctly and all of the detents are behind the metal... . Just wondered if anyone else encountered this problem or if I goofed up the install somehow....
I understand you to say that the fuel door housing is shifting, not the taillight housing. Anyway, yes, I never even noticed it, but my fuel door housing does have a slight rotation to it. It's been on there since early last year without issue, so I wouldn't worry about it.
that's a lot of cash for a fuel door just to say jeep. I would expect that it didn't move at all! You know what I mean? I am a picky person..... just a small rattle and I want to fix it. How could "mopar" make a part that dosen't fit for their main compadre? I wonder if the Rugged Ridge or another company has the same "gap?" Either way I didn't get what I paid for...
Yall that say it's only when you are fueling actually grab it and try to rotate it cc and see if it moves? maybe it is that wimpy a$$ piece that sticks out on the LH side to align it properly.......
well I cannot notice a gap or rattle..... however I know that it moves and that in the long run it could cause wear on the paint?? How so ever slight it may seen I am picky...... You know?
