Mopar 60 axles locker help
So bought the Spicer ultimate 60 axles for my 2015 Jk. Wired up and cannot get the lockers to work. We wired direct to battery and you can still rotate tires opposite directions. Hooked to factory harness with connector it came with and still does not work. Anyone have any information that can help me? We thought maybe bad locker but tried front and rear
when you say rotate tires different directions, do you mean it is still on jackstands and you are spinning them by hand?
You may need to rotate both tires the same direction to clock the carrier into a position where the locker can engage.
