MOPAR 2" lift as recommended by Dealer (Does not VOID warrantee)
I have been searching the forum but cannot find much about the MOPAR 2" lift (apart from it being expensive at 1599$) However looking at the lift kit, I get everything in need to lift my 2010 4dr Sahara, giving it much better offroad performance without compromising on its onroad performance, right?
So any thoughts on installing a MOPAR lift (the good, bad and ugly)? I like that the lift is OME and doesn't VOID the warrantee (allegedly) I will be running 305-70-R16's Yokohama's on Procom's.
I like the 2.5" TeraFlex lift as well but the kit at Q doesn't come with all I need so probably will spend in the end the same as a MOPAR lift....
Are you allowed to install the lift to maintain warranty or does it have to be installed by the dealer? I know when I had my F-250 the back up lights I wanted had to be installed "professionally" to maintain the warranty.
Huge upcharge.
Is your dealer giving you something in writing, from the factory, that says a lift will not void the warranty? Or will the 'dealership' give you a piece of paper stating that you get a 1-year parts only warranty? I am guessing it is the latter. Which means you pay all labor if there is problem with the lift. And if there is a problem with a non-lift component that fails because of the lift, they can still point at the lift and tell you to go pound sand.
So IF they are actually offering to cover it under the full factory warranty, it may be worth the price. Since I am guessing that is not the case, you would be much better off with an aftermarket lift and installing yourself.
Sponsoring Manufacturer
Their charging you $1599 for 4 pucks and shocks? That's like $1000 just for labor. You can get the RE lift, they make the Mopar lift, for under $600. There are plenty of other puck lifts that you can get for well under $300. Any lift install could void the warranty, but they have to show that the lift caused the failure.
It is the only lift the dealer is willing to install.........so it is professionally installed hence considerations can be made incase of a failure. thank you for your comments !
I have a good relationship with Quadratec hence i would be buying the 2.5" Teraflex lift through them, so I need to add the following ?
Trackbar + stabilizer
set of lower adjustable control arms
Do I need to change my pitman arm?
What about brake line extension brackets?
anything else?
Cheers,
Mark
