Mopar 1/2 door assembly video?
My 1/2 doors finally came in yesterday. Picking them up today. I've been looking for an assembly video with no luck.
Anyone with a link or with any experience in putting these together would be appreciated.
![FJOTM Winner](https://i.ibb.co/FgFLpFN/Untitled-1.jpg)
There isn't a video that I've ever seen but putting them together is pretty easy. I separated the pieces into two piles and put the two doors together simultaneously just mirroring what I did on each side. I don't recall anything being too tough, just be sure to get your key cylinders keyed before you look at the install because they go in very early.
Did you have the painter adjust your door hinges before painting them?
I read in the instructions that if you have power door locks you have to "replace the 2-way connector with the supplied 10-way connector." Is this just an unplug and replug or are there wires that need to be cut etc...?
Thanks,
SP
I actually reused the original hinges on the half doors and they take some adjustment after you put them on the jeep to get them right. I used blue painter's tape in the torx bolt heads as to avoid chipping the paint when I was adjusting them.
To your question on the harness- I put these together for a 2010 with no options so I had the 2 wire harness coming out of the jeep and I installed the supplied 2 wire harness. The 10 pin harness went into the trash bin.
I had a friend stationed overseas who left his jeep with me and he sent parts. After I got all of the parts installed then I shipped it over to him. It's back stateside now. No pics because the forum doesn't like uploads from my phone.
I was wondering... I can get the new half door locks re-keyed to match my full doors... but what about the electric locks, activated by the key(s)? How is that matching accomplished?
Thanks,
SP
I don't know that the power locks will work unless you put the actuators in there. Obviously without any options on my friend's jeep, there were no actuators to be installed. Your electronic lock/ key will tell the jeep's computer that your jeep is allowed to be opened so the alarm won't go crazy on you.
The two wires on his doors were quite literally just a "signal" to tell the jeep if the door is open or closed. I've got the same two wires on my full doors (zero options here as well).
Jeepsareus sells the actuators and harness for putting electric locks on half doors
This is the link they provided me when I asked the same question.
http://www.jeepsareus.com/jeep-wrang...lectric-locks/
Hope this helps
Hope this helps
Hope this helps
Hope this helps
http://www.quadratec.com/products/55014_1211.htm
http://www.quadratec.com/products/55014_1210.htm
