Modified smittybilt src rear bumper?
![](/images/ranks/veteran_army.png)
Has anyone done this before? I found one i can get for my JK that is brand new for $250 without the tire carrier. I am digging the look of this JK with the src rear and the OR-Fab tire carrier combo. Only thing i want to do is maybe cut off the side tubes to the bumper kind of becomes a stubby and does not stick out like that. What do you guys think of that because there is a great deal on this bumper locally ? Also because i have the XRC MOD front bumper and want the looks of the rear to be the same style.
http://www.fortec4x4.com/OR-Fab-8520...mited-JK.html#
I have seen it done many times and it looks good , I have also seen it done with the front and it looks good to
Pictures might be a little hard because I know it has been since 2010 the sat time I saw it
I don't see why you wouldn't do it if that's the look you like. I considered that bumper but the tubes on the ends were too much for me. I went stubby out of the warehouse but the rugged ridge price is certainly worth it to chop the ends and spackle it with bedliner to hide the surgery.
UPDATE: I picked up the bumper for $240 and installed it already. Ill give it a few days or a week to see if im going to add the tire carrier or not. If i decide to buy the tire carrier i will have the latch mechanism cut off and make something to where it opens with the tailgate. I have seen it done just cant find pictures. Also take off part of the tubing that goes toward the wheel well so the tires dont hit when it flexs ( Issue will come in to play when lift and bigger tires are finally installed ).
Linkage to connect to the tailgate and tire carrier like this.
http://www.quadratec.com/products/13008_1024.htm
I had the exact same thoughts of trimming mine... UNTIL I rolled back and hit hard. The corner tube saved both my tail light and tub. Now I won't even consider another bumper without the same protection. I run 35's with a 4" lift, no problems when the rear is stuffed.
![](http://img.tapatalk.com/d/14/02/25/etyruvy5.jpg)
- sent while my wife wasn't looking
