Modifications to run at High Altitude
I'm planning a week in Colorado. I'll be at 8600 ft for the week. Does anyone have any suggestions on making the jeep run at that altitude? I do have a superchip programmer.
Thanks
Thanks
I've had the JK over 8000 feet several times. Apart from reduced power, everything worked fine. The power loss is due to reduced oxygen because of lower atmospheric pressure. It will run a little rich (or they used to before computers) but it doesn't hurt anything.
When you get to high altitude country, you will probably notice that "regular" gas is only 85 octane. As Ron said: "The higher the altitude, the lower the octane you can run."
