Mod Suggestions - Ride Quality
#41
I have also done a lot of reading about the OME kit. I have read 2 threads about the coil options, both threads seem pretty conflicting. ...
The OME kit is great but probably gives even more lift than ...
ex. 618 is a 2door heavy rear, 620 is a 4door heavy rear. What happens if a 2door gets the 620 or a 4door gets the 618? Or two different JK's are using the exact same coils, but one is a 2door manual with a soft top, and the other is a 4door auto with a hard top and bumper/winch/carrier and lots of body armor. Same coils, but are these two JK's anywhere close to the same height?
#42
I have a 2011 Rubi Unlimited, and have the Teraflex 2.5 coils, using my Rubi shocks with extensions, and I run 33's and have a ton of room to put 35's should I ever want to. My ride is great, it has not changed in the negative at all. My wife was thinking it would ride like my 09 "X" with a R/C 2.5, but it does not. I would highly recommend this set up.
#43
I currently have a 2010 Rubicon Auto Two Door. I am just finishing up my Bushwacker Flatties and going to install a set of 35x12.5x17 MTR's on stock Rubi rims with 1.5 spacers. I'm going to ride it around for Awhile then install my BB with 2.5 springs and shock extensions using my stock rubi shocks. I actually ordered the unlimited package for my two door to compensate for my aftermarket bumpers and winch. We will see if it's too stiff or not!!
#44
Picked up my Jeep last night. It is much taller than I thought, even stock. I may just go with the leveling kit for now and get some 33s and see how that looks. I will not be out much money and can move to a bigger lift if I choose to go with 35s.
Should I just stick with the cheap TF Leveling kit, or go with the coil based?
#45
#46
#47
