Mismatched steering components
I'm looking into replacement tie rods. I'm leaning toward the steer smarts yeti. I like the no flop design. I have a synergy drag link that is seriously beefy and has given no problems but it "flops" down with has always bothered me...it actually makes slight contact with my factory tie rod. My question is does anyone have the yeti in combination with the synergy drag link? I'm wondering if there will be any clearance issues. I could go with the synergy and get the misalignment boots that will limit the movement i suppose. If I went that route, the synergy would be roughly $60 more. Any thoughts?
I don't know the specifics as I don't have the yeti tie rod but had a friend recently returned his due to a very loose fit on the tapered ends (it should be a tight interference fit).
You are going to get a lot of differing opinions here but add Fusion 4x4's steering to your list to consider. Lots of people here are running it and are very happy. Last tie rod you'll ever buy.
I don't know the specifics as I don't have the yeti tie rod but had a friend recently returned his due to a very loose fit on the tapered ends (it should be a tight interference fit). You are going to get a lot of differing opinions here but add Fusion 4x4's steering to your list to consider. Lots of people here are running it and are very happy. Last tie rod you'll ever buy.
A few companies now are building less forward/backward misalignment into the tie rod ends including SS, MC, TF. Synergy/RS use spacers to prevent flop in their joints.
Ah yes good call. I had forgotten about that. Although it WAS the yeti tie rod that was specifically for Reid knuckles. If people have had a good experience with yeti, then by all means, go for it. This was just an odd situation that caused my friend to question their quality and I know the company was looking into the issue.
Edit it was the DL stud hitting the tie rod forging.
Screen shot BF rig
This is becoming a bit of hearsay but there were two separate issues. There was a concern about the stud length but that wasn't the cause of the loose interference. He could have ground down the stud to fix that issue, but the concern still remained about the second part of that.
