The mirrows that fit onto the door hings?
Old 05-29-2012 | 02:27 PM
GulfCoastJeeper's Avatar
Best pic I have of mine $12 oreilleys.
Old 05-29-2012 | 02:55 PM
powerlineguy's Avatar
Originally Posted by tbone in tx
I use one of these. Part number 91983-03B
Cost ~$35 dollars and works perfectly with no shaking. I keep it in the back with and tighten it down just enough with a wrench and it doesn't move. We've had 20+ MPH winds regularly and no shake at all doing 70....
This times 2. Not sure if this is the same part number as mine but I went with the short arm Harley Davidson mirror. Love it. Does not shake or vibrate at all. I keep mine in the back too so it's always handy.
ID:	323215   Click image for larger version
Old 05-29-2012 | 03:22 PM
chrisswank's Avatar
Originally Posted by mpkelley20
Dietech Offroad makes brackets that fit into the top door hinge and you use your factory mirrors. Kind of a pain to take the stock mirrors off (2 bolts each side) but if you leave your doors off a lot, the brackets give you near stock viewing and you get the full size stock mirrors including the fold in feature when wheeling in tight spots. I have them and actually bought a second set of factory mirror (I got them cheap) so it cuts my install time down quite a bit.
I recommend the Dietech mirror brackets as well. I purchased a second set of factory mirrors and they work great.
Old 05-29-2012 | 04:00 PM
jnew32's Avatar
I also went with a Harley mirror. $19 and it doesn't move at all ever just hand tight.
Old 05-29-2012 | 04:20 PM
robsjeep9's Avatar
JK-Forum Ambassador
Yeah the part number they gave me was
91909-03B and 91910-03B driver/passenger
Mine were black what color have you guys ordered maybe that's why the part numbers are different or cause I'm in Canada????
Old 05-29-2012 | 04:23 PM
I wasn't saying it was wrong...Just that i wasn't sure because I don't remember the part #. But now that you gave the left and right #, that sounds familiar because I remember the last digits were different.
Old 05-29-2012 | 05:12 PM
stryke-force's Avatar
I use the dietech mounts, purchase another pair of mirrors and its a quick install. A little on the costly side but well worth it.
Old 05-29-2012 | 06:53 PM
Warwick2008's Avatar
I use the Olympic Safari mirrors. They do shake, but for the price, I can live with it. However I did discover when I stuck on some 3" convex mirrors from Autozone, the white sticky pad on the back of the convex mirrors acted like a shock absorber and images in those mirrors are steady as can be while driving.
Old 05-29-2012 | 07:24 PM
SWAMP RAT's Avatar
Where are you guys getting them from at this price. The cheapest I've found is $27
Old 05-29-2012 | 08:04 PM
IN the BLACK's Avatar
Default Ridecraft on Ebay are the ones you will want.
I like these 5 X 8 mirrors for about $80. Clear view and no shaking. Perfect.
Quick Reply: The mirrows that fit onto the door hings?
