Might be ditching rock krawler springs, need help
I’ve had my X factor kit a little over a year now. From day 1 it’s been really stiff. Originally thought maybe it was the shocks, so I ditched the rock krawler shocks for falcon 3.3s. Definitely some difference there but I still feel every imperfection on the road even on the softest setting. Thinking of going with synergy. Now here’s my dilemma. I wanna put 5.5 spring up front. With the rock krawler kit, I have 4.5 and had to put a spacer up front because the kit never got rid of the factory rake. I was thinking of going with a 4” rear coil so I would t have this issue again. Don’t wanna put a spacer on top of a bigger coil. So should I go with 5.5 rear coil or 4.0?
Former Vendor
What kind of tire are you running? From the sounds of this, I'd venture to guess Load Range D or E which isn't correct for a Jeep when you want a good on road ride. What kind of tire pressures are you running? Also, for the rake, are you running a spare tire on the back? What kind of bumpers? Winch?
Adam C
Adam C
